#74879 - 25/02/2002 13:57 Glowing horizontal grid wires on display
Neo_to_Rio
Loc: Silicon Valley
Is it normal to see these wires glow on a Mk2? They're not very bright, but can be seen on my amber filtered display under low ambient lighting.
Something I can fix with a soldering iron and a component change?
#74880 - 25/02/2002 14:23 Re: Glowing horizontal grid wires on display [Re: Neo_to_Rio]
frekin
Read this thread (I sure hope the link displays correctly):
http://empeg.comms.net/php/showflat.php?Cat=&Board=empeg_tech&Number=69108&page=0&view=collapsed&sb=5&o=0&fpart=
I asked the same question on Feb. 14th.
#74881 - 25/02/2002 15:51 Re: Glowing horizontal grid wires on display [Re: frekin]
Neo_to_Rio
Loc: Silicon Valley
Thanks frekin. That thread pretty well covers this issue. Guess I'll just learn to ignore it.
Too bad there wasn't a good transflective LCD display available at the time the Mk2 was designed. Seeing the filament wires at night is a very minor issue compared to seeing nothing at all when the top is down and the sun washes out the display.
Barry
#74882 - 25/02/2002 15:52 Re: Glowing horizontal grid wires on display [Re: frekin]
Okay, made a FAQ entry. I know "2" doesn't count as "frequent", but it was easy enough.
#74883 - 25/02/2002 17:16 Re: Glowing horizontal grid wires on display [Re: Neo_to_Rio]
There still isn't anything which we'd consider suitable - we wanted fast response times and something we could use behind a panel to make the ID work simple. VF still has the edge for this sort of stuff, which is why high-end (non OEL) car audio still uses it. OEL is nicer, but wasn't available publically at the time we wanted to use it.
#74884 - 25/02/2002 23:08 Re: Glowing horizontal grid wires on display [Re: tfabris]
ninti
Loc: Los Angeles
I think it is actually three times now Tony, so you're good.
Just change the name to FAQAQNATFBWBIWDHSAWOCFAQM.
(Frequently Asked Questions And Questions Not Asked That Frequently But Would Be If We Didn't Have Such A Wonderfully Obsessive Compulsive Frequently Asked Questions Maintainer)
