#78307 - 07/03/2002 10:01 Failed to unmask IDE
Anonymous
Unregistered
That's what it said while trying to boot up. This has never happened before and it booted up fine on the second try. I'm using 2 beta 11. Is this something to worry about?
#78308 - 07/03/2002 10:11 Re: Failed to unmask IDE [Re: ]
I don't think so (I wrote the kernel code that results in that message). It's a probabilistic thing in the kernel, dependent on how much I/O is going on at the time, with a 3 second timeout.
I suspect the player issues the unmask command at the same time that lots of other disk I/O is happening, and sometimes it just doesn't get done within the three second allowance.
(note that there's been a "fixme" note on that code since the beginning, but nobody's ever gone back and fixed it).
I'll increase the timeout to 6 seconds in the next Hijack kernel.
#78309 - 07/03/2002 15:13 Re: Failed to unmask IDE [Re: mlord]
Nic
Loc: Marlow, UK
My empeg had been getting that message a few times. I had put it down to my rapidly failing IDE cable, which I've since replaced. Since then I haven't seen the message at all. The message never failed to go away without a swift reboot
#78310 - 08/03/2002 17:33 Re: Failed to unmask IDE [Re: mlord]
Anonymous
Unregistered
#78311 - 05/06/2002 12:07 Re: Failed to unmask IDE [Re: mlord]
Derek
Loc: NRW, Germany
Just had this for the first time on my empeg yesterday, running Hijack 271 ... does this kernel have a fix for this in it?
