#79294 - 10/03/2002 18:01 Setting LastPlayed using emptool (2.0-b11)
ickiller
Loc: Hombrechtikon, Switzerland
Hi together.
I wrote a perl script some time ago that synchronizes my local MP3 Library with meta information stored in a MySQL Database to my Empeg using emptool.
This script also saves some tags (mainly LastPlayed, SkippedCount and PlayCount) reported by emptool into my database for further use.
After a harddisk upgrade last weekend (replaced the drive), I synchronized my MP3 files back which worked without problems.
But then, I wanted to set these tags (LastPlayed, SkippedCount and PlayCount) back to the values I saved before, but that didn't work. The values stay the same.
I tried it manually with emptool to make sure it's not the fault of my tool:
/All my Discs/Roxette - Stars> lookup 99e0
2405 99e0 I\ Was\ So\ Lucky\ (Tits\ &\ Ass\ demo):
type = tune
length = 4057966
title = I Was So Lucky (Tits & Ass demo)
PlayCount = 0
SkippedCount = 0
LastPlayed = 0
artist = Roxette
comment = 2735
source = Stars
year = 1999
codec = mp3
bitrate = fs128
offset = 0
samplerate = 44100
duration = 253622
tracknr = 3
mp3db_trackid = 2735
So, all three values are zero. So I set it and did a sync:
/All my Discs/Roxette - Stars> set LastPlayed=1014324244 99e0
2402 Set LastPlayed=1014324244 for:
/All my Discs/Roxette - Stars/I Was So Lucky (Tits & Ass demo)
/All my Discs/Roxette - Stars> set PlayCount=2 99e0
2402 Set PlayCount=2 for:
/All my Discs/Roxette - Stars> sync
The sync reported no errors and after the restart i checked the values again and they were still zero:
type = tune
length = 4057966
PlayCount = 0
SkippedCount = 0
LastPlayed = 0
artist = Roxette
In the lookup listing of another post (Re: "Least Recently Played" is definitely HOSED in) i saw other fields like play_count and a comment that LastPlayed is Bogus. I don't get such lowercase versions of these tags reported by emptool.
I was unable to find more information about the differences between this tags (mixed case and lower case ones).
Does anyone have more information about this tags? How can I set these tags using emptool?
Thanks a lot.
Roli
#79295 - 11/03/2002 07:57 Re: Setting LastPlayed using emptool (2.0-b11) [Re: ickiller]
Those tags (Marked, PlayCount, LastPlayed, SkipCount) are special, in that they live in a read-write disc area on the player (the "dynamic data" area), rather than in the *1 files. At about line 980 of Emptool's playerdb.cpp, you can see them being read out of the binary structure...
...unfortunately, nothing in Emptool seems to be writing them back to the dynamic data area (instances of those tags in the *1 files are ignored). This is a bug in Emptool.
Incidentally, SkipCount isn't implemented on the player either,
