#82677 - 21/03/2002 00:58 USB issues
visuvius
i'm having trouble using USB with Emplode on XP. It works intermittently. Like last night, it worked fine; it got past "uploading tunes" but then there was an error when "restarting player", the songs still uploaded fine though. Then tonight, it recoqnizes the player in emplode, but then when i click OK, it says "There doesn't seem to be a player connected". WEIRD. I have latest emplode and hijack.
any helP?
#82678 - 21/03/2002 09:27 Re: USB issues [Re: visuvius]
dodgecowboy
Loc: Mississippi State University
This just tends to happen with XP, its a pain, but it happens, whenever it happens just pull out your USB connection and then reinsert it. If it happens at the end of a synch, then just hit synch again and it will finish, you dont have to upload again its all still there
Lucas S. Starkvegas, MS
#82679 - 21/03/2002 11:23 Re: USB issues [Re: visuvius]
This is a known bug in the current software. It only happens on Windows XP. They are trying to find a solution.
In the meantime, you can use Ethernet to work around the problem.
#82680 - 22/03/2002 04:37 Re: USB issues [Re: tfabris]
The good news is that Roger now runs XP and is experiencing all of the USB problems that have been reported. This bodes well for a fix!
#82681 - 22/03/2002 05:21 Re: USB issues [Re: rob]
More to the point, Mike runs Windows XP, and is _also_ experiencing the problem. Since he wrote the USB driver, this bodes even better for a fix.
