#89014 - 18/04/2002 08:27 keep harddisks spinning !
pupvogel
Loc: Hamburg, Germany
Would be nice if harddrives kept spinning in certain situations...(say, on PARTYS or so...). Otherwise they have to spin-up before the just-selected song starts.
This would be an helpful option during emplode-sessions... but it could also be implemented as a Setting in the Advanced Player Configuration...
...or is this possible already ??
#89015 - 18/04/2002 08:35 Re: keep harddisks spinning ! [Re: pupvogel]
Yep.
[options]
spindown=0
Ought to do the trick. I think it made it out into beta11.
#89016 - 18/04/2002 09:08 Re: keep harddisks spinning ! [Re: Roger]
pupvogel
cool !
but...where do i put that line ?
are there more gimmicks like that one ???
#89017 - 18/04/2002 09:16 Re: keep harddisks spinning ! [Re: pupvogel]
pupvogel
ah ok, config.ini, got it !
#89018 - 18/04/2002 09:39 Re: keep harddisks spinning ! [Re: Roger]
tms13
Loc: Lochcarron and Edinburgh
Using Hijack, you could prefix this with ;@AC so that you don't have the drives spun up in the car...
It would be nice to have some UI to set spindown=0 for the current session (i.e. lost when the power is removed), and this should be doable in Hijack. This would be useful for occasional parties for those of us who wouldn't want it on all the time.
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#89019 - 18/04/2002 10:06 Re: keep harddisks spinning ! [Re: tms13]
xn00dlesx
But would It be a Bad idea to have this turned on in the car ? Would a really bad bump cause damage to the harddrive ? It would solve the buffer problem with it sometimes taking a few seconds to go to the next track , correct ?
#89020 - 18/04/2002 10:12 Re: keep harddisks spinning ! [Re: xn00dlesx]
smu
Loc: Germany (Ruhrgebiet)
It would. Many reasons for this.
Yep, that's one of the reasons. One other reason is that a spun-up harddisc certainly consumes more power than a spun-down disc (but there is certainly a trade-off, because a disc spinning up uses even more power than an already sun-up one).
It would certainly reduce the latency between selecting a new song and the start of the song playing. But it would certainly not eliminate it completely.
cu,
sven
