#89155 - 18/04/2002 17:04 jemplode cannot control play music??
akihiro
Loc: Kanagawa Japan
I cannot use play icon (Jemplode menu)
why??
#89156 - 18/04/2002 17:50 Re: jemplode cannot control play music?? [Re: akihiro]
'Cause he hasn't implemented that part yet.
Hijack's got some great features in that area. Mess with that. Especially CharcoalGray99's XML interface to Hijack.
#89157 - 21/04/2002 17:04 Re: jemplode cannot control play music?? [Re: tfabris]
akihiro
Loc: Kanagawa Japan
I understand.
Tahnk you.
and I want play control on Macintosh.
how to do that?
#89158 - 21/04/2002 17:09 Re: jemplode cannot control play music?? [Re: akihiro]
You will need a PC to load Hijack for the first time, following the instructions in the FAQ. After that, a Macintosh using a web browser will work the same way as a PC for the HTML remote control capabilities.
PS: I am aware that it's possible to use a mac to write new flash to the player, but it's tricky and I'm crossing a language barrier here, so I'm trying to keep the instructions simple.
#89159 - 21/04/2002 21:52 Re: jemplode cannot control play music?? [Re: tfabris]
Has anyone worked much with OS X and the empeg via serial? In theory, OS X should allow similar instructions to be written as the Linux ones...
#89160 - 22/04/2002 19:56 Re: jemplode cannot control play music?? [Re: drakino]
mschrag
Loc: Richmond, VA
If anyone can get serial to work on OS X then let me know -- If you can, then jEmplode will work over it also.
Mike
