#91951 - 04/05/2002 21:15 Splitting Firesign Theater
I'm considering taking my ripped copy of Firesign Theater's "Don't Crush That Dwarf, Hand Me the Pliers" and splitting it up into tracks with titles for each section. It's only two tracks (side 1, side 2) as it comes out of the box.
Any firesign theater fans already done this? How would you title the tracks?
#91952 - 04/05/2002 21:28 Re: Splitting Firesign Theater [Re: tfabris]
Satan_X
Loc: Ramsey, NJ
I feel your pain. When they trasfered the 1st Husker Du album (Land Speed Record) to CD they did it as two tracks (Side 1 & Side 2). I haven't had the raw courage to take on that yet.......
VW R32 Empeg 50gig 'Stormy 3 has snuck in a dodgeball' - Stormy 1
#91953 - 04/05/2002 21:32 Re: Splitting Firesign Theater [Re: Satan_X]
My Gapkiller program has a fairly easy-to-use splitting feature, the only hard part is deciding where to put the track breaks. Note, if you use Gapkiller remember that the file must have only ID3v1 tags on it (you can re-add V2 tags after you're done messing with the files), and if you split VBR files you need to fix up the headers on the resulting split files (for instance, with MP3 Tag Studio).
#91954 - 05/05/2002 11:23 Re: Splitting Firesign Theater [Re: tfabris]
Greetings!
I left mine whole. In almost all cases, I listen to this sequencially anyway. If you want to break it up for ease of upload or listening:
a) mark your favorite bits first and split these out and give a name that makes sense to you
b) break the remaining sections into evenly timed bits (say 5 or 10 minutes per file, give or take a bit based on content - works best if it is an even multiple of your daily commute)
c) don't bother making sane references to the evenly timed bits, maybe just some cryptic "DCTD1.1.4" mimicing the ever popular SCSI / Unix convention c0t0d0s0...
I have done that for some of the old National Lampoon Radio Hour I had laying around, but generally I leave it as one bit.
#91955 - 06/05/2002 16:24 Re: Splitting Firesign Theater [Re: tfabris]
Micman2b
Loc: Central, NC, USA
Is this the Firesign album with "Side 5" also?
_____________
Sean in NC
130gb MK2a w/ 32mb ram
80gb MK2a empeg spare
#91956 - 06/05/2002 16:42 Re: Splitting Firesign Theater [Re: Micman2b]
No, it's just got "This side" and "The other side".
#91957 - 06/05/2002 20:51 Re: Splitting Firesign Theater [Re: tfabris]
Ezekiel
Loc: NH USA
See? It's split for you already!
-Zeke
WWFSMD?
