#97597 - 04/06/2002 22:04 Hijack config error
MisterBeefhead
Loc: Crete, Il USA
...is what it says every time I boot my Empeg. No problems that I have noticed, but the error message is annoying. I tried reinstalling 2.11b and Hijack to no avail. Is there something I'm missing?
_____________________________ It's getting to be ri-god-damn-diculous.
#97598 - 05/06/2002 01:07 Re: Hijack config error [Re: MisterBeefhead]
You'll get that error if there's something funky in your config.ini file. Post it here so we can have a look if you want.
If you haven't enabled it in emplode the easiest way to get to it is probably via the http interface. I think it's in the /drive0/var dir from memory.
#97599 - 05/06/2002 09:48 Re: Hijack config error [Re: MisterBeefhead]
If you are having trouble with your config.ini file, please click here.
#97600 - 05/06/2002 11:28 Re: Hijack config error [Re: tfabris]
MisterBeefhead
Loc: Crete, Il USA
Thanks guys, it turned out to be the config.ini. 10,000 lines in the favorite visuals section.
#97601 - 05/06/2002 11:57 Re: Hijack config error [Re: MisterBeefhead]
Remember, to avoid this problem in the future, do not synch more than once during a given session of emplode. Always completely exit emplode after performing a synch in 2.0beta11.
