Hello
I have some problems getting my player to work after i put on beta11.
The upgrade went fine, and the player worked.
I started emplode and had a look around. I found a menu I hadn't seen/used before. (Can't get the name in emplode now, because the player doesn't respond.)
The menu allowed me to enter my name/phone/email adr., after this I synced and the player just stopped responding.
This is what comes out of the serialport. (I pasted in the latest part, this just keeps scrolling over and over)
empeg FM radio driver (Philips).D DAC: 00000015
RAM disk driver initialized: 16 RAM disks of 4096K sizext cycle will ignore flash
empeg dual channel IDEpawning too quickly, i
Probing primary interface...
Abnormal player
No drives found, retrying...iolation at pc=0x020be39c, l
No drives found, retrying...000000000000
hda: IBM-DARA-206000, ATA DISK drive
, code 2)ount
hdc: no response (status = 0xa1)<0205d04c>] bf
Control: C
hdd: no response (status = 0xa1)ip : bffffe5c fp : bffffe58
No seco
r10: 02006718 r9
hdc: no response (status = 0xa1)fe74 r9 :
Re
hdd: no response (status = 0xa1) r5 :
No drives found, retrying...erminal
Restarting system.
Registering drives...g-car v0.07 19991106
ide0 at 0x040-0x047,0x078 on irq 7
player: memory vio
If there is
hda: IBM-DARA-206000, 5729MB w/418kB Cache, CHS=12416/15/63ak now,
Partition check:
or for
hda: hda1 < hda5 hda6 > hda2 hda3 hda4t fly the Penguins of Linux!layer
RAMDISK: ext2 filesystem found at block 0e 2)partition
Clearing 8Mb of R
Calling linux kernel...music
VFS: Mounted root (ext2
Control: C83D517D Table: C83D517D DAC: 00000015
player: memory violation at pc=0x020be39c, lr=0x0205d04c (bad address=0x0000000) r1 : 000
r7 : bffffe9c r6 : 00000008 r5 : 00000000 r4 : 00000000
r3 : 020f7b58 r2 : bffffea4 r1 : 00000000 r0 : bffffea0
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user
pc : [<020be39c>] lr : [<0205d04c>]
sp : bffffe4c ip : bffffe7c fp : bffffe78
r10: 02006718 r9 : 00000000 r8 : 00000000
Respawning too fast, next cycle will ignore flash
Respawning too quickly, ignoring flash settings
sp : bffffe2c ip : bffffe5c fp : bffffe58
r7 : bffffe7c r6 : 00000008 r5 : 00000000 r4 : 00000000
r3 : 020f7b58 r2 : bffffe84 r1 : 00000000 r0 : bffffe80
Still respawning too fast, rebooting...
I have tried to use both consumer/developer. (I had developer installed when
it stopped working.)
Any ideas??
TommyE
