Yeah -- There are really four scenarios here:
1) the tags are the same, the song is the same -- always should be rejected as a duplicate
2) the tags are different, the song is the same -- maybe we should reimport just the tags?
3) the song is different (but sounds the same) -- replace the song on the empeg
4) the song is different (and sounds different) -- add a new song
It looks like the code for songprint is only like 150 lines to compute the signature, but it uses FFTW (the Fast Fourier Transform library), which I'm sure is rather large. I need to either port FFTW to Java, find a replacement, or use the java wrappers and require the dll or .so (which would suck).
ms
