Sweet!
I'll give it a try when I get home tonight. In testing, if you wanna have flite write to a temp file rather than stdout, you can specify an output filename as a second arg. A filename of "stdout" is a keyword that triggers my modifications, any other filename will run the regular unmodified code.
My goal is to get rid of the ttsd shell script and have everything it does integrated into flite. In 1.0a2, pcmcvt is now integrated so that's one down. Next up will be pcmplay. After that, I'll see about having flite sit in an endless loop reading from the fifo. I haven't tried yet, but I suspect it may be harder (having to worry about resetting globals and such that are expecting the program to end).
With IrDA support on the empeg end, I guess I'd better get started writting code for my pager too so I can test it out. By default, it beams stuff in a Palm-compatible format (memos, contacts, todos, etc) ... maybe there are already tools available for Linux to interpret those kinda things.
--The Amigo
