There's no FAQ on changing lenses, you just need a 2.5mm hex wrench and you need to be gentle. Those bolts should only be finger-tight. If you cinch them down you'll crack faceplate or worse, crack the non-replaceable fascia part.
Creating animated logos is outlined here. Note this only covers the tools, can't help you with the part that involves having artistic talent.
