No wait!!!!!
It's simpler than that.
That was the problem with the other mapping program. With this one it's not nearly as thorny an issue. The problem is that each turn contains two data points that are the exact same point. For example:
52 -4942
252 -4957
253 -5154
253 -5154
Take the Stewart St. exit 166 to Denny Way
246 -5177
234 -5307
233 -5328
That should be VERY EASY to fix in the script, right?
For anyone but you, apparently
