Here is version 7 of set_empeg_max_fid.c
This one does the same max_fid fixes as prior versions, but now also expands the stored running order and bookmarks sizes to handle larger numbers of fids.
Run this on *any* player version to gain support for:
-- running orders (Eg. down-down-down shuffles) of up to 43648 fids, which should now survive reboots with this fix.
-- larger bookmark capacities (a bookmark is merely a saved running order): 43648 fids for bookmark #1, and 40917 fids for bookmarks #2 and #3.
Those features will work regardless of disk size.
In addtion, v7 will automatically reconfigure any slack space at the end of the dynamic data partition on the player (/dev/hda3) for use with fids > 0x6fff, according to available space. The larger the drive, the larger the (free!) gain one typically sees from this.
250633-set_empeg_max_fid.c (415 downloads)
