You can use WDS to bridge multiple APs together without having to run a physical cable between them. It will totally kill the throughput however since WiFi is half duplex. Each hop you add will halve the available capacity. Thats after the reductions caused by distance as well.
Range extenders are basically very small APs doing WDS back to the main AP.
