1) Does not continue to run after power removed (1.1 Did)
Correct; I didn't want to modify the init script, because of a lot of problems resulted from it. The way it is installed now doesn't affect the player app, only when it is started in the menu.
When trying the Test Index 1, showed playlists, but when clicking on the play button, it returns an error
If you looked at your empeg, you would have noticed that your empeg started playing the selected song/playlist. The errorpage is some debugging info.
icons:
checkmark : select playlist
floppy : save mp3
speaker : stream to pc and play through mediaplayer/winamp/etc
triangle : play playlist/song on empeg
3) When I first tried to run the Index 2, I clicked on a song and it returned an error. I replaced the raw with mp3 in the HTML and now it works.
test2.html was just an example for the first alpha version. Some things have changed and the links don't work anymore
Frank van Gestel
Frank van Gestel
