Here's my hyperterminal output if it helps....
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v508 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Fri Jan 9 16:06:35 EST 2009
Processor: Intel StrongARM-1100 revision 9
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102295) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x99380
Tuner: loopback=0, ID=-1
show_message("Hijack v508 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004e00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x8080
ide_data_test: wrote 0xffff read 0x8080
ide_data_test: wrote 0xaaaa read 0x8080
ide_data_test: wrote 0x5555 read 0x8080
ide_data_test: wrote 0x0000 read 0xefff
ide_data_test: wrote 0xffff read 0xefff
ide_data_test: wrote 0xaaaa read 0xefff
ide_data_test: wrote 0x5555 read 0xefff
hda: WDC WD2500BEVE-00WZT0, ATA DISK drive
hda: WDC WD2500BEVE-00WZT0, 238475MB w/8192kB Cache, CHS=30401/255/63, LBA48
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:08:f
7
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press Starting player
Timezone: EST
Restored terminal settings
Abnormal player termination
Player received SIGINT, user interruption
Switching to shell-player loop
Starting bash.
Shell exit
Starting playTimezone: EST
er
Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment"
kftpd: listening on port 21
khttpd: listening on port 80
player.cpp : 385:empeg-car 2.01 2004/07/06.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Starting bash.
empeg:/empeg/bin#
Check out The Tremors the best hillbilly rock n roll you ever set your corn fuel soaked ears to.
MK2a 250gig #030102295
