Originally Posted By: tonyc
I use 3x 3TB Western Digital WD30EZRX drives in mine, in a RAID5 configuration.
You might want to use the Western Digital WD30EFRX 3TB drives instead. This is the 'Red line' of products instead of the 'Green line'. The Reds are specifically manufactured for use in NAS'es (or other RAID setups). If you're going to setup an unRAID server, then forget I mentioned this and use the Green line range.
