What I like about these numbers is that you're now incentivized to store your electricity rather than feeding it back
How feasible would it to set up, your presumable hot water heater, to only run when there is an excess of solar energy, rather then all the time? Although this could leave you with cold water in the morning, maybe just restrict the lower element, so the upper can still heat a smaller amount of water.
In other word, without resorting to batteries and other means of storing energy, is there a way we can automatically consume the excess PV energy when it is available, rather then sell it to the grid at a low price, only to buy it back later for double.
We've got two 50-gallon natural gas water heaters (piped in
series with one another -- which my plumber says is something they'd never do any more). In the summer, they account for the bulk of our gas bill, which will hover around $25/month. I'm looking to replace them with a new high-tech hybrid tank or a tankless, either of which would be radically more efficient. So storing excess electricity in hot water isn't particularly attractive.
What
is attractive is over-air-conditioning the house. While the usual environmentally friendly thing to do is to run the AC less during the day when you're not home, then have it come up to speed when you're on your way home, I could instead keep the house cool all day, perhaps even cooler than I want it when I'm home, consuming a big chunk of my excess solar production. This is better for the house, in some regards (cooler air = drier air => less mildew/mold), but would put more wear on the AC compressor/motor.
If I were super high tech, I'd bury a cold water tank in the backyard and I'd store
chilled water, for the AC to use whenever I needed it. Chilled water distribution is commonly used in commercial system, where they might chill water all night, when power is cheaper, and then use it all day. If I were building a house from scratch, I'd look into this. Needless to say, it doesn't appear to be an easy retrofit.
