Note that I ordered last year's model, the 9360, because it still has USB 3.0 Type-A ports, as well as a single USB-C/Thunderbolt-3 port. The Thunderbolt port has only 2 PCIe lanes, which means it cannot drive a full 4K monitor attached to the WD15 dock at 60Hz -- but it can do it at 30Hz. It can also instead drive a pair of WUXGA (1920x1200) displays at 60Hz, which is our use case here.
The newer model 9370 has no USB Type-A ports, but does have two USB-C/Thunderbolt-3 ports, at least one of which has 4-Lanes, and can use the WD15 to drive a single 4K monitor at 60Hz. or a pair of WQXGA (2560x1600) displays at 60Hz, as well as various other lessor combinations.
So, if one can live with lower battery life (the 9370 has a smaller battery) and no USB Type-A ports, then the newer machine is better equipped for high resolution external monitors.
Or if like me, one prioritizes battery life (larger battery in the 9360) and USB Type-A ports, then the older model is worth considering.
USB-C to Type-A adapters and cables are readily available of course, but not as nice as just being able to plug a random USB stick or wireless keyboard dongle directly into the notebook.
Other differences between the two years models are 2X speed interface to the NVME SSD on the newer one, and better heat piping to reduce thermal throttling. The processors are identical, the RAM is the same. The newer one can be had with a higher rez screen than the older one, but I skipped on that kind of thing because it kills battery life.
