>If you're getting 4v on the 5v rail, you may have blown something
>on the main board - check the 3 fuses on the main board near
>the display connector. These are only generally blown if
>the display board connector is plugged in a pin out.
Hugo, you're a god!
The three little white fuses all look fine to the eye,
but the one closest to the rear docking connector shows
infinite resistance -- the other two are fine at 0 ohms.
Do these just feed directly to the ribbon cable header
for the display board? If so, I'll check for shorts
on that line before blowing the replacement fuse.
I don't think I ever plugged the connnector on wrong,
but anything is possible at this point. I'll pick up
a replacement fuse tomorrow and see if things behave any better.
Thanks!
