After getting the run around from UPS about customs issues, I went home and performed the hack myself... for the most part it works I got it all soldered up and realized that I'd soldered both top and bottom LED's wrong and damaged one of the solder points on the top... I did get it to light up, however I can't adjust the dimness now.... So basically three of my buttons work the way they should and the top one just stays really bright all the time. I need to stay away from the soldering iron from now on.
Brett 60Gb MK2a with Led's
