#294470 - 01/03/2007 18:23 car speakers - advice?
julf
I'm finally getting around to upgrading the sound in the Morgan. Unfortunately space is really at premium. Seems only possibility is 2 x 8 in woofers in fairly small boxes (10-15 l) behind the seats, 4 in mids in 100 mm holes in the front footwells, and free-air tweeters at both ends of the dash.
I have been thinking about Focal-JMLabs elements - 21 WX Be woofers, 4Kslim mids, and Tbe tweeters. But unfortunately I don't seem to find any place that would sell them! Googling around it seems Focal has stopped selling individual elements
Any suggestions for suitable alternatives, as well as suggestions for suitable *small* 2 x 300 W + 2 x 150 W or
4 x 250 W amps?
#294471 - 01/03/2007 20:57 Re: car speakers - advice? [Re: julf]
Last time I was at Andym's I noticed he still had the custom sub he had made for his old Smart. It was pretty slim, and packed quite a punch. Even if the box won't fit the speakers sounded pretty good to me.
Brabus also had the cool idea of putting a sub under the seats of the smart firing up, no idea what it sounded like, but I bet it was quite a ride for the ladies
Cris.
#294472 - 01/03/2007 21:03 Re: car speakers - advice? [Re: Cris]
http://www.earthquakesound.com/sws.htm
I've got the 2 x 6.5inch package. Robricc got them on my behalf in the US. Pretty good performance, I'm told the bigger units are even better.
#294473 - 01/03/2007 21:11 Re: car speakers - advice? [Re: andym]
The finished article
There are some more photos over at riocar.org
#294474 - 03/03/2007 11:27 Re: car speakers - advice? [Re: Cris]
julf
I like the idea, but that would assume there was some space under the seats in a Morgan...
#294475 - 03/03/2007 11:38 Re: car speakers - advice? [Re: andym]
julf
They look ideal if the main isssue is lack of depth for mounting a traditional woofer. But on the Mog, there is a fair bit of depth available behind the plywood panel behind the seats. OK, at some point you will hit the rear diff...
I am also a bit suspicious of anything with "earthquake" in it's name. I am not looking at listening to surround soundtracks of disaster movies, and I don't need to be able to set off car alarms while waiting for a green light. Insetad I want a clean sound with sufficient volume to cope with the rather significant wind and engine noise - a german car it isn't.
For the same reason I have a bias against elements with glow-in-the-dark neon surrounds (and furry dice).
The Focal elements would have been perfect...
#294476 - 03/03/2007 19:44 Re: car speakers - advice? [Re: julf]
What's in a name? Yes they can be driven very hard (the cone excursion on the drivers are really quite impressive) but I simply used them as reinforcement for the bottom octaves. If I'd wanted earth shattering bass I'd have gone with a much more substantial setup than the one you see above.
#294477 - 04/03/2007 08:32 Re: car speakers - advice? [Re: andym]
julf
OK, good to hear - just seems that pretty much any car sound outfit I have seen over here is focusing on "boom for your buck"... :-/
#294478 - 04/03/2007 08:54 Re: car speakers - advice? [Re: julf]
boxer
Loc: Yorkshire UK
....besides, the whole point of a Morgan is that you can tell which way up a coin is, when you run over it - you wouldn't want to spoil that boast!
