#98519 - 10/06/2002 06:37 upload crash
willebear
Loc: Louisville, KY USA
i am having trouble with my new empeg. i have successfully uploaded about 5500 files but the process has become very buggy. It first crashed when i got overzealous and tried to upload about 50 albums.
It then took about an hour to reload in emplode (the "checking disk integrity" ran for a long time (apparently ran thru twice) and then the error log listed albums that "did not match actual # of children detected"
i went back and deleted those albums referred to by this error.
now when i try to upload even a few albums it crashed. now it won't even finish its inital synchronisation in emplode.
error = "download failed ... #0x80072736"
oh yeah, i'm using xp
and emplode 2.00 beta 11
hijack is also installed - checked the pins on the ethernet cable and they are fine
thanks for your help!
Edited by willebear (10/06/2002 06:47)
50 Gig MK2 feat. over 7445 songs, 865 albums by 400 artists for 25 days of easy listening
#98520 - 10/06/2002 06:53 Re: upload crash [Re: willebear]
Greetings!
Questions:
a) Are you running Hijack, and if so, what version?
b) What is your hard drive configuration?
c) You are using XP - are you uploading via USB or ethernet? USB is known to be buggy under XP.
Observations:
To be honest, 50 albums at a shot is not overly zealous. I have loaded huge chucks on music at a shot, and not had difficulties. The disk check running for a long time is normal - it is fsck'ing the hard drives. I am guessing you are dual drive, since it ran through twice. This is normal, as long as it is not extreme (I see fsck times of 45 minutes per drive, but that is because I am at the extreme end of things.) I suspect that you are seeing one of the following problems (you can search the BBS for more info):
a) a buggy XP / USB interface
b) an early version of Hijack without the checkpoints in place
c) a bad crimp on your hard drive cable
If you are running the developer kernel, I would reboot, drop to shell, follow the procedure for fixing hard drive problems and trying again. If you continue to see problems, post a boot log - maybe something is sick there.
If it is a bad cable, you will need to contact support for a replacement.
#98521 - 10/06/2002 07:43 Re: upload crash [Re: pgrzelak]
willebear
my player is currently being installed so i cannot check the hijack version yet
i am using xp with ethernet.
which is the latest version of Hijackl and where do i get it (mark lord's site?)
can i just install the new version 'over' the old one?
thanks
#98522 - 10/06/2002 07:50 Re: upload crash [Re: willebear]
Greetings!
You can install the new hijack directly over the old one. The link to Mark's page is in the header on the BBS - just click on Hijack Kernel above. Good luck with the install! Take photos!
#98523 - 10/06/2002 11:04 Re: upload crash [Re: pgrzelak]
willebear
what if hijack is on the head unit but not installed on my pc? i have emplose 2.00 beta 11 but have never installed hijack on the actual pc.
does this matter??
#98524 - 10/06/2002 11:06 Re: upload crash [Re: willebear]
SE_Sport_Driver
HiJack only installs on the player. It never installs on the PC.
#98525 - 10/06/2002 19:13 Re: upload crash [Re: pgrzelak]
willebear
hijack version 272 is currently on there. is till can't add files to the playlist without a "synchro..fail .. 0x80072745"
i am trying to install hijack 275 but using the image editor, i keep getting a cannot open port message. i think it's port 1 - i tried all 4 with no luck
uggghh
#98526 - 11/06/2002 03:46 Re: upload crash [Re: willebear]
Greetings!
Are you able to get to the shell prompt? Did you try fsck'ing the drives? Can you post a boot log? Thanks!
