The amp looks good for your application, and it's nice that you've got all 5 channels covered in one amp.
In reply to:
"Lightning 8 Gauge Powerlink Kit" (what is this?)
$29.95
This is the wiring kit for your amp. It uses 8 guage power wire (great for one amp installation). It includes the power and ground wires, RCA cable (1), fuse, etc.
In reply to:
cables and wires
$38.35
With the Lightning kit, you get all the wiring you need except for speaker wire from between your amp and speakers, and two RCA cables to go to your front/rear outputs. I assume that's what this is for, and is actually quite reasonable for all that wiring.
Where are the mounting the amp? In your trunk, or are they putting it into your custom console? Just wondering why they are charging you for the same amount of time to install the amp as the empeg?
-Trevor
