Here's what I have so far:
1) support for */? matching in search strings
2) support for wordbreak character in search string
3) ctrl-shift-c that appends to clipboard rather than ctrl-c that replaces the clipboard
4) (maybe) make the clipboard appear as a playlist (so you can modify what you're going to paste)
5) allow "marked" to be bulk set/unset
6) fix the soup sorting issue
7) drag-n-drop reordering
8) drag-n-drop copy-n-paste
9) reliable deduping
10) fix bugs with multiple-select play/insert/append buttons
11) per-playlist sort options
12) fix bug with sorting mixing order of equal values
13) empeg<=>pc syncing aka Empeg Backup
14) ogg import / tag parsing
15) flac import / tag parsing
Am I missing anything?
On the "Emplode vs jEmplode" post, a couple people mentioned that the Java UI had some quirks ... I'm curious what people most dislike. It may be possible for me to fix some of the quirks that people most dislike ...
Mike
