The wheel planes are not parallel in the (first) photo. The front wheels are turned slightly to the right, giving you a more straight on view compared to the rears. You are seeing a projection of the rear wheel at a greater angle than the fronts, so the linear dimension (horizontally) of the projection is different. Try measuring them vertically.
Jim
