Using different interfaces (serial, USB, ethernet) to the empeg won't cause a problem (as long as you don't try to use them at the same time).
While on the subject, you ought to upgrade to v1. It doesn't have any USB fixes in it, per se, but there's a heap of other good stuff in it.
emplode can be a bit finicky. Did you hit refresh a couple of times? Does the empeg-car appear in Device Manager?
Failing that, reinstalling the empeg USB driver can help.
Roger - not necessarily speaking for empeg
roger
