> Does the empeg-car appear in Device Manager?
I take it you mean under Universal serial bus controller?
If so, then no. There is only an Intel 82371AB/EB PCI to USB Universal Host controller and a USB Root Hub under it.
Ah, then this is a problem with the USB driver on the unit, or on the PC. At this point, I'll have to bow to Mike's superiour knowledge.
> Failing that, reinstalling the empeg USB driver can help.
How? I ran the emplode setup program.
Yes. That's the simplest way to reinstall the USB driver. You may want to try uninstalling it first, then reinstalling it.
Roger - not necessarily speaking for empeg
roger
