Greetings!
Hm. Perfect. It also shows that both of the hard drives are being located, and that they are being read properly, showing up as the right type of drive and size:
Probing primary interface...
hda: IC25N030ATCS04-0, ATA DISK drive
hdb: IBM-DJSA-220, ATA DISK drive
hda: IC25N030ATCS04-0, 28615MB w/1768kB Cache, CHS=58140/16/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
It also shows that it is finding the partitions correctly on both drives (hda & hdb):
Partition check:
So... This gets a bit more interesting.
Do you have the developer version of the player loaded, or the consumer one? If you have the developer version, you can get to the shell prompt by typing "q" after it boots. If you can do this, please do the following and let me know what happens:
cd /drive0/var
ls
cd /drive0/fids
ls
cd /drive1
ls
cd /drive1/var
ls
cd /drive1/fids
ls
Basically, I just want to look around to see what the player thinks it sees in these directories.
Paul Grzelak
