OK.. all is well again.
But I didnt have to use logoedit to send anything to the player at all. Weird.
I was going to remove the config.ini file from the player and upload a new copy. I performed an RWM command on the player.. after a few minutes I got the command prompt back.
At that point I saw your post about sending the code with logoedit..
So I next performed an ROM just to make sure, then an EXIT. It booted. I loaded emplode, removed the line of code causing the problem, synced.. and here I am again. A hardy 'Yee Haw' from the land of Texas for the help!
Thanks!
Carl Aydelotte Dallas Texas USA empeg MKII 080000506 40gb-green
