The dimensions on the site are very, very misleading. The real volume is quite a bit larger then the advertised volume.
Yes you said so a thousand times in a thousand forums, well done. Someone [censored] up the web site and no doubt someone will get fired.
Now stepping briefly into the real world. You bought a player. It is packaged in CLEAR PLASTIC. If you didn't like to form factor, you didn't have to buy it. Even if you couldn't be sure from the packaging, you have every right to return it.
Some people will want the taller thinner iPod with 8 hours battery life, some people will want the shorter thicker Karma with 15 hours battery life. It beats me quite where you thought that extra battery life was going to come from without making the unit bigger!
Rob
