Jules,
I attempted to run ESMC this evening without luck. It's seems to be crashing at about the 2500 track mark when building the initial database. I am running v2.0 final and hijack v389. I added the config file changes and the EmpegLink file using the CMD file that you supplied. I attempted the load 4 times with similar results. The player has 2 drives (60 & 80gb) with about 1.5 GB free. Is it possible that its crashing on a bad track? If so is there a way to tell which track or the last track read before the crash.
Thanks.
