There's a fix for this in the v1.0 branch of the code (might make it out into the wild in a hypothetical v1.02), and in v1.1. It sorts the imported tracks and directories alphabetically (by filename) at each level of recursion.
It's done by filename because it's easier, and because quite a lot of people put the track number at the start of the filename anyway.
v1.1 also deduplicates playlists and tunes when you drop them in, so you can just pick up your root music directory, and drop the whole lot in.
Roger - not necessarily speaking for empeg
roger
