You mention getting 0.1.4 to work with "...router-based DHCP servers." So does that mean if I have a 4-port typical hardware router that also provides my DHCP services, I can't run tRio right now? So is the work-around solution to manually set the IP address of my PC that runs ARM and then allow the ARM to provide all DHCP service to the Rio Receiver?
Thanks,
Judd
