I had the same problem (slow net access when streaming). Here is what Paul suggested to me (which worked).
1. Try changing the multicast-ttl setting to "0" in trio.xml. It's on the
same line as the multicast-address setting.
2. Try the other send-method settings, "broadcast" and "unicast".
Changing the send-method to broadcast worked for me.
Edited by FrankyG (17/08/2003 18:18)
