> First off, the init that it created was blank
The empty init should be fixed, the applet should also work normally now
> M3U (using winamp) comes back w/ 401 authorization is required
That's true; you can shut off authentication by giving an argument to displayser
so instead of starting with
# ./displayserver
use
# ./displayserver noauth
In fact you can give it any argument you like it only checks for the parameter.
I'm currently implementing some configfile.
You can use mediaplayer, realplayer or sonique to use authentication.
The latest realplayer visuals are great...
Frank van Gestel
