I've had this problem before, or rather
almost this problem. Only this time I cant fix it.
It started a few days ago. I began to get odd audio artifacts (clicks, pops, squeals, etc.) on tracks I KNOW are good (because I checked my local copy). Now granted, it could be that they've become somehow corrupted on the player. But I'm also now getting the "No Hard Disk Found Please Contact Support" message.
At first I was able to do the "pull it out, re-seat it" trick and it would be good to go. Now however, it simnply won't work at all. I get the error every time.
I was able to effect a short term fix by reloading 2.0 / hijack, and everything seemed to be ok until I slotted it into the car, then back to "normal", meaning "No Hard Disk".
Boot Log Follows
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v413 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Tue Aug 17 18:05:30 EDT 2004
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 40104034) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9877c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005a80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: FUJITSU MHL2300AT, ATA DISK drive
ide0: unexpected interrupt, status=0x58, count=1
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman ([email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:c2
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
End Of Boot Log
I've done the following:
- Verified the crimp on my cable (the culprit the last time this happened to me)
- Searched for, and failed to find, dry solder joints on the IDE interface.
- Checked jumpers: I have no jumper on the secondary drive, nor did I find one lose in the unit. I don't remember there ever being one on the second drive
I see nothing physically wrong with the internals, nor is there any odd odor. The empeg tastes like a normal empeg.
I
did notice that there is no reference to the CS4132A chip in the boot log. Is this a case of it not getting that far or does Tony need to fix the FAQ to read CS4231A? THAT ONE is in my boot log.
I found the following FAQ articles as probable appropriate reading/references:
I got an error message about 'e2fsck' at the shell prompt. What do I do to fix it? Why does it say 'No hard disk found contact support'? (As well as all articles referenced from this one)
Any help / advice / info anyone could offer would be greatly appreciated...
