#249924 - 20/02/2005 19:53
Re: Lack of Central forum Activity
[Re: The Central Guy]
Quote: From our previous thread, if I remember, the conclusion we reached is that the large HD support is not built into the boot firmware in the Central...And it won't boot with two hard drives either....What ideas did you have?
Neither the boot kernel in the firmware, nor the second kernel on the disk, nor the kernel on the upgrade CD understands big disks (>128Gbyte). You could get the Central to work with a big disk, but only if you were a Linux geek: you'd need to plug the big disk into a Linux PC, partition and format it manually in the way the upgrade CD would, initialise the swap partition, copy the root filesystem from a standard Central disk, and replace the second kernel (it's somewhere in the root directory ISTR) with one you'd cross-compiled yourself from our sources but with the LBA48 patch too. This is not a project for the faint-hearted, but it's no more recherche than some of the stuff people do to their car-players.
