Hi All,
After a little bit of advice please, after my empeg woes last week.
I'm considering cutting my losses and selling up and finding an alternative solution to providing mp3's in the home and car.
So in the bundle i would be selling my empeg and the accessories.
The Empeg is a Mk2a, with 20gb and 30gb Fujitsu drives in it (50gb total). It is working but needs some TLC to make it perfect.
It needs a new Rotary Encoder. The IDE Header I think is slightly faulty as now and again i get No Hard Disk Found. One or two reboots normally cures this. The display has gone dim, which according to the FAQ is a blown fuse, though i'm personally no expert and haven't the ability to check. You can still read the display if you are close to the machine.
I have the following accessories:
- Car Sled - Used. This is mounted in a self contained box inside my glove box and i will remove it as such to reduce damage to the sled.
- Home Dock - courtesy of MLord. Painted black by myself, so its diy style rather than the professional piano back finish i've seen elsewhere. Just setting expecations ....
- Remote Control. I will replace the battery for you.
- 6 Lenses. One has a broken corner but works fine.
- Empeg Box. Ok it's not an accessory but i do have it.
I would be prepared to ship worldwide should i decide to sell.
So my question is what sort of value could i expect for this bundle be it in US Dollars, £££'s or Euros.
Many Thanks
LTJ
