OK, I've released a new version with only two changes:
1. I've added a 30 second sleep before it does anything to allow the empeg time to startup in case this is started from hijack with EXEC_ONCE.
2. It no longer rescans your drives every time. It only perform the scan if the empeg's /drive0/var/playlists file has been updated more recently then it's database. This means your drive is only remounted read write for a second in order to write a process ID file unless you've just updated the music on your empeg in which case it does a scan for new music. I'm assuming people want the pid file bit left in so that it can be killed from hijack (see Drakino's post above for an example how).
I've created a web page with instructions (mostly just the first post from this thread) and downloads
here.
-Mike
