You *have* to hard jumper the drives...
...or hard not-jumper the drives. As Rob says, cable select is not supported by the empeg. These days, hard drives often come out of the box jumpered for cable select, and you need to check that the jumpers are on the correct pins (or that you've taken the jumper off completely, as appropriate).
