How exactly do I release the kernel part?
You could start by posting it here as an attachment. Then I can have a look-see and decide how best to incorporate it into Hijack (based mostly on code size, compatbility, etc..).
Mark,
Attached is my driver for the Seeburg Wallbox. It consists of two files (attached). The sampler runs in linux/include/asm-arm/arch-sa1100/time.h and the driver is in a separate file seeburg.c
I also made the following small changes in three files (in pseudo diff -c)
file:drivers/char/serial_sa1100.c line 2342
#ifdef SERIAL_DEBUG_OPEN
printk("rs_open %s%d, count = %d\n", tty->driver.name, info->line,
info->state->count);
#endif
+ //hack -- force on DTR because driver doesn't
+ if(line==1)
+ GPDR &= ~EMPEG_SERIALDTR;
+ //hack-end
file /drivers/char/mem.c line 699
extern void empeg_cs4231_init(void);
extern int empeg_power_init(void);
+ extern int seeburg_init(void);
+ seeburg_init();
#ifdef CONFIG_EMPEG_RAMTEST
file: arch/arm/special/notify.c line 40
#define NOTIFY_FIDLINE 2 // index of 'F' in notify_chars[]
+#define NOTIFY_SOUNDLINE 6 // index of 'S' in notify_chars[]
#define NOTIFY_MAX_LENGTH 64
static char notify_data[NOTIFY_MAX_LINES][NOTIFY_MAX_LENGTH] = {{0,},};
+const char *notify_sound (void)
+ return &notify_data[NOTIFY_SOUNDLINE][0];
302342-time_upload.h (932 downloads)
