Yes, I tried to start it with startkde. Why is that wrong? (I'm not arguing with you, I just want to learn)
I have done absolutely no configuration at all yet. Just installed Suse, and configured for Belgian keyboards and Vesa resolution 1024x768@75Hz. That's it.
Ok, so I've tried startx now, it also doesn't work. This is the error message. (is there any way I can cut and past this? - I now have to type everything which is pretty annoying)
xauth: creating new authority file /home/archeon/.serverauth.3511
X Window System Version 7.2.0.
Release date: Sat Sep 22 22:10:58 UTC 2007
X Protocol Version 11, Revision 0, RElease 7.2.
Build Operating System: openSUSE SUSE LINUX
Current Operating System: Linux linux-103 2.6.22.5-31-default #1 SMP 2007/09/21 22:29 UTC i686
Build Date: 22 September 2007
Module Loader present
markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) Warning, (EE) Errorn (NI) not implemented, (??) unknown.
(==) Log File: "/var/log/Xorg.0.log", Time: Fri Jan 11 19:17 2008
(==) Using config file: "/etc/X11/xorg.conf"
(EE) FBDEV(0): FBIOPUT_VSCREENINFO succeeded but modified mode
(EE) FBDEV(0): mode initialisation failed
Fatal server error:
Addscreen/ScreenInint failed for driver 0
giving up.
xinit: Connection reset by peer (errno 104): unable to connect to X server
xinit: No such process (errno 3) Server error.
That's it. Does that help?
