OK, I've seen a number of useful replies to my question. I will
- test whether the empeg case is grounded with the RCA cables off
- try powering the empeg direct from the battery
- try grounding the empeg direct to the chassis
- try a 10A power filter I just bought
- try combinations of the above
I have already made a number of cables I will be able to test with as soon as my empeg is returned from being repaired.
But there's one other quetion on my mind: if I power the empeg directly from the battery, will I need to use a relay for the switched power lead? Otherwise, only the permanent power will be clean; the switched power will not be clean. Or does the player only draw current from the permanent power lead?
