Start iTunes and plug the turned on iPod in. It should detect that an iPod has been connected and offer to do a restore.
There are a few problems with that scenario. I can't turn the iPod on. All I can get is (briefly) the Apple logo, then a warning message (Triangle with an exclamation mark in it superimposed on a stylized iPod) saying "www.apple.com/support/ipod".
iTunes does not see the iPod.
The "Enable disk use" repair routine does not work.
Forcing a reset (lock-unlock-menu+select) resets, but only to the Apple logo which then goes to the above warning message.
It is well and truly bricked.
It might be hardware trouble. It was working perfectly half an hour before it failed when I did a small sync, and it wasn't dropped or bumped or anything afterward. But now if I click Menu, I hear a steady click-click-click from the hard drive while the Apple logo us up. The clicks are at a rate of exactly four per second.
Wasn't there a repair technique for the Karma in similar circumstances that involved rapping it sharply on the table or something?
Sigh...
edit: I can verify that the Karma repair technique works on the iPod as well. After banging it fairly hard on the edge of a table (harder than cracking an egg on the edge of a skillet; not hard enough to drive a nail unless into very soft wood) the hard drive spun up, iTunes would talk to it, I did two syncs to test it, and everything seems fine. Banging the back of it was what did it -- banging the edges did nothing.
Whether it is a permanent repair, time will tell.
db
Edited by tanstaafl. (24/02/2009 06:12)
