I'm complaining about crucial because their products don't work reliably at any voltage.
Something about your system or environment is causing failures.
The parts should work reliably at 2.0v, but the problem is that they're not actually 2.0v parts. Running at that voltage you're overclocking the parts.
The parts are tested for operation at 1066MHz at 2.0V. It doesn't mean that they're overclocked.
Intel and AMD have varying CPU core voltages depending on what speed grading the CPU is. The 3.0GHz part might require 0.3V more than the 2.5GHz part. Is it also overclocked in your opinion?
