I *thought* it looked garbled. I was afraid it indicated something was wrong.
Hyperterminal only mangles the output when you try to use the clipboard (ctrl-C) to copy the diagnostic output. If you use the "capture text" feature it works fine. Look
in this FAQ entry here for more details:
You can also grab a complete boot log for diagnostic purposes. This is done by Selecting "Transfer, Capture Text" to begin creating the log file, then "Transfer, Capture Text, Stop" when you have captured the desired activity to that file.
Note: Some versions of Hypterterminal, specifically the one that comes with Windows XP, have a severely bug-ridden copy/paste function that scrambles the lines of text as they are copied to the clipboard. If you are trying to capture a boot log for diagnostic purposes, use the Capture Text feature instead.
The reverse is not true, however. If you have been given a list of diagnostic or repair commands to execute at the shell prompt, it is safe (and recommended) that you copy and paste the commands instead of trying to type them. The shell prompt is very sensitive to mistakes in spacing, spelling, and capitalization, and pasting the commands will produce the best results.
