It looks like we are back to the SSD not being detected. Is it plugged into the same spot on the cable it was last time?
Mark, any idea if this is a potential bad IDE header issue where the drive works only as a slave device and not master? Though what I find odd is that things worked when both hard drives were in the system. Maybe a bad cable instead (the crimping issue?)
