The easiest way to install ds2 on the empeg on 2.0 is first downgrade to 1.03, use emplode to upload ds2b2.mp3 to the empeg, then reinstall v2.0 developer-image. After that, connect empeg over serial and start empackager. It should find the file and start the install-program
To install the new executable :
- open hyperterm and start shell
# rw
# rwm
# cd /tmp
- use send-file option in hyperterm to send file ds2b2.mp3
# cd /opt/ds2b2
- check if you are in the right dir
# ls -l
if you see this line :
-rwxr-xr-x 1 root root 95783 Oct 4 22:48 ds2
it means you've got the old beta2 version
move the old executable :
# mv ds2 ds2.old
- copy the new one to the dir :
# cp /tmp/ds2 ds2
- make the new file executable :
# chmod +x ds2
- check the new file
# ls -l
- output should look like this:
-rwxr-xr-x 1 root root 93103 Oct 24 23:46 ds2
- remount the disks ro :
# ro; rom ( or rom;ro. I think ro only is sufficient to remount all disks ro, haven't checked)
- reboot empeg (pull plug)
